Limit on local RSNs? | SatelliteGuys.US
Hockeyfan16
20
I currently get
MSG
FSNY
YES
NESN
This spring, the Mets will have their own network, "SNY" launhed. Provided Direct TV picks it up, that would be my 5th RSN. Is that OK? Just seems like alot.
I believe some southern NJ markets trump you, anyway (NY and Philly RSN's)
Either way - people with the Sports Pack will tell you there's no limit on the number of (mostly useless) RSN's you can have. :)
D10-300 or D10-100
Pointing a Gain Master Dish
