Less than 7 day guide now on 721 | SatelliteGuys.US
ken
296
Since I got the new software for my 721 last week I am now only getting 6+ days on my OSG. If they keep to this I am going to be PO'd. Anyone else having this problem? I have also been having a bunch of other problems since then.
Perhaps you should try turning the receiver off at night when it is not in use to see if that resolves the problem or try to reboot the receiver. I would think that it would download it from the second tuner when it is not in use though unless you have timesr in the morning hours when it usually gets the EPG data.
I have tried to reboot it with no luck but in over 2 years of use I have never had to turn it off at night in order to get the 8 day guide. But I will give it a try.
DISH to show "Stolen Honor" a POW's Story
