Length of cable between EA dish and hd receivers | SatelliteGuys.US
ecarl4100
31
Tennessee
The best place I have to mount my eastern arc dish is about 200 to 225 feet from the receivers in the home. I don't really have any other realistic options for mounting the antenna. Is this length going to be a problem? Is there a line amplifier of some sort that can be used if it is an issue? I really appreciate any help you guys can give me.
It will probably work at that distance. There are in line amps available, but I doubt that you will need it.
I just did a buddys install of an EA dish it was about 235 feet and it works fine. He has the same signal strenght as mine, and I only have about 75 feet of cable between the dish and receiver. I bought good quality rg6 cable from sadoun sat sales (link above) that was the key. Plus they sell by the foot. Use a good quality cable and you should be fine.
625 loses picture
Does it?
