P pjm8047 SatelliteGuys Pro Original poster Apr 27, 2004 304 0 syracuse,ny Jan 23, 2010 #1 can i run a 222k on a legacy lnbf or do i need a dish pro lnb?
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,405 14,931 Mankato, MN Jan 23, 2010 #2 Legacy equipment will work on all receivers I have heard issues with HD receivers and using Legacy LNB's for 129 (it may not recognize 129 on a switch setup)
P pjm8047 SatelliteGuys Pro Original poster Apr 27, 2004 304 0 syracuse,ny Jan 23, 2010 #3 i'll be running the 110 and 119 for now. might hd later .dish tells me i need a dishpro lnb.
P pjm8047 SatelliteGuys Pro Original poster Apr 27, 2004 304 0 syracuse,ny Jan 23, 2010 #4 i have legacy quad lnb. do both 222k sat inputs need to be hooked up to view on one tv no pip?
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,405 14,931 Mankato, MN Jan 23, 2010 #5 If it is a dual tuner then yes you need 2 cables form the LNB. You cannot use the separator
P pjm8047 SatelliteGuys Pro Original poster Apr 27, 2004 304 0 syracuse,ny Jan 23, 2010 #6 can i just use one input?
boba SatelliteGuys Master Dec 12, 2003 11,350 1,036 Dorchester, TX. Jan 23, 2010 #7 Iceberg is correct dual tuner REQUIRES dual cable inputs
