Can you elaborate on this? Scott is mum on the subject. The word is that Dish is "watching us". To me, if they don't fix this bug, it renders the DVR useless and I will jump ship to prove a point. Oddly, when I have watched Euro 2008, the FF Scan bug was non-existent. However, everything else is still affected.
- Scott is on Vacation.
- I don't know what you mean "Dish is watching us"
- To clarify, I have conversed with someone in Dish Engineering and they are working on the Fast Forward problem. Note that the problem with L510 (delayed or recorded satellite-delivered 1080i HD Locals) rendered those channels unwatchable, so a fix was quickly delivered. In this case, you can use the 30-second skip ahead instead of FF, so in this case, it seems likely that Dish will be more careful and test the fix (L512 ?) more thoroughly before we get it.
L511 killed my 722 on June 17. It seems that if you add OTA HD locals, and then reset or pass through the 3 am update, the box gets stuck in the Acquiring Satellite Signal loop. (never gets past 3 of 5)
If you reset to factory defaults, and don't add OTA, it works again.
The worst part is I called for service and they replaced my box (taking all my stored programming away with the old one) and the same thing is happenning.
I should have come here first to see that it was a software problem and not a hardware problem. Too bad the DISH representatives were equally ignorant.
Joel
Joel
Limited time offer
