ku analog help | SatelliteGuys.US
ku analog help
Techfizzle
Banned
985
if i point to a bird that has a analog ku test card... plug in my receiver (toshiba trx-1200) hit ku and the channel up through 32 channels.. i dont get anything... do you have to set it up like a regular fta receiver or not?
the analog box usually has the frequencies in 20khz steps started with TP1
TP1=11720
TP2=11740
TP3=11760
etc
and they alternate polarities...make sure the frequencies are set up properly and that you have the correct polarity
Also if your slaving it, you may need to tune to a H or V transponder on the main box, as it will control the polarity. Thats what I need to do with mine.
How to get best quality on new hdtv?
receiver does 4:2:0 and 4:2:2
