Just pictures of my 90cm | SatelliteGuys.US
jholt5638
80
49
Toledo, Ohio USA
I just got around to taking some pictures for troubleshooting ( signal issues) So I thought I'd port them here Dish is aimed at 103W with second LNB aimed at 97W
Anyone think the short fence is causing any problems. The tree blocks the arc past 87W and I've picked up as far as 123W. Currently pointed at 103W and a second LNB pointed at 97W. Trying to figure out why I can't lock in 12080 H 30000, I had it a few days ago seemed to coincide with a thread on Ricks about a power increase on that TP and disappeared again when it was posted the power was back down. Am I just out of luck till I can go up to a 1.2m+ dish? Is 12080 a weak TP or am I just not tweaking the dish enough?
Receiver is a ZGemma H5-AC connected to a 4x1 switch with a 3db noise rating
First LNB is an Avenger KSC321S2 Universal Single Linear 0.2dB Ku Current SNR by TP
11760 H 30000 11.5db
11880 H 30000 13.1db
12134 H 4600 9db
12080 H 30000 0.0db tune failed
11942 V 20000 10db
12145 V 20000 9.1db
12180 V 25000 12db
Second LNB is an Avenger KSC322-2 Universal Dual Output Ku Band LNBF and is aimed at 97W
228 Tv and Radio channels
Avg SNR 7.3db
11760 H 30000 11.5db 60
11880 H 30000 13.1db 57
12134 H 4600 9db 0 no lock
12080 H 30000 0.0db tune failed 0 no lock
11942 V 20000 10db 68
12145 V 20000 9.1db 68
12180 V 25000 12db 63
Avg SNR 7.3db
Cannot provide db numbers, but put in Quality numbers from Azbox running Openatv 6.0. In Canada, the Maritimes on a 1.0 metre Wineguard. My lnbf sits a bit loose in the holder and aims a hair high I believe. Will fix it some day. A couple cedar branches could be in the way also.
Catamount
Catamount
12134 H 4600 9db
11942 V 20000 10db
12145 V 20000 9.1db
12180 V 25000 12db
Avg SNR 7.3db
I have the same dish, and 12080 has always been a tough one. Just moving the dish a hair can be the difference between a good signal and nothing on the tougher 8psk muxes. I don't think I've seen that transponder since installing my motor.
I realized i had to have a 1.2 meter on 103w to get those tough muxes, and i needed a 1.2 meter on 87w to get those tough transponders. When i had a 90cm on 103w, those muxes were hit and miss. Not very reliable. Same with 87w.
With some difficulties, finally, next dish pointed to 87 W
I need help with ku please.
