Yes, please do.I will have to scan it some time and post the scans so anyone can see some of this old stuff from the 80's.
No the Rat Shack one was a copy & a POS. It had a bunch of plastic crap in it the warped badly. This one like like the 9 ft Janeil stamped perf. Either sting the button hook or even better get 4 pieces of conduit and go to the edge for a quad pod feed. IIRC it was an f/d of .4 and being 9 ft had a beam width of less than 2 deg image rejection.I found these pictures that linuxman had posted on the forum here in 2007. The mount and motor on this Janiel dish, look just like the mount and motor that are on the dish that I harvested. I managed to scratch off where my motor had been painted over and see that the motor was made by Janiel it is a RP180 model. I wonder if Janiel made these for Radio Shack, as the dish looks like a Radio Shack dish. Here is the link for the thread with the pics.
Gonna disagree w/ you on the conversion. The pot positioners had drift problems in nearly all cases (due to it "counted" via resistance and length of wire could cause problems). I converted a bunch of birdview pot to reeds as they had some of the worse drift problems and dropped the use of the pots themselves.Yes, please do.
I didn't dabble in the hobby back then, but it's still fun finding all the old adverts and documentation for was was often very well built equipment! - :up
As for the original Janiel positioner/controller, you might get it going with that.
One of our members got a very old actuator, and instead of converting it to reed switch, found the original controller, hooked up the existing pot, and is running that way now.
Nothing at all wrong with saving the reed-switch conversion to a later date.
Just get the tank running.
You can clean the plugs and boil out the carburetor later.![]()
That brings back nightmares. That was the better dish like the one here. The receiver was a Uniden that was guaranteed to fry the positioner from heat. Uniden later redid the model so that the positioner box was in a separate unit.Looks like the dish that radioshack sold at one time.
Radioshack 1990 Satellite System - YouTube
...Did you have to convert that motor to a reed sensor type design? I read on here in a previous post that I might have to do that.
Limited time offer
