Is this correct: No blind scan | Page 2 | SatelliteGuys.US
Just got altrxo, yes it's fast but only if I scan a small range of symbol rates. If I scan all symbol rates >1875 it won't find everything, so than I have to set the delay further up, which I don't know how to do yet. Also an annoying glitch, it finds the same tp in both h and v? Either it's not changing polarity or it's really sensitive.
To get it working you have to go to properties and set a compatibility mode.
I just did a test with my Satellite Finder, if the light gets dim it's vertical, if the light is bright it's horizontal.
Right when I start the scan it gets dim but 1 second later it got bright again and stayed like that through v and h.
try altrxo, it's much faster
Anyone willing to share their settings on the Altrxo software for blindscan? I am not getting good results, but maybe my setting are whacked.
Also, when trying to use the BxS software, it tells me I don't have the proper software installed, try installing it, then load the blindscanner.
Also, what version of drivers are you all mainly using for blindscanning with the skystar 2.3p card? I just got mine today, but was having mixed results.
If someone that has the Altrxo software could post a screen of their settings, I would much appreciate it.
Hi mate, i still haven't spent much time tweaking it so i wouldn't be able to tell ya.
But in what regards BxS's, it needs to have technisat's setup4pc software installed in order to work.
DVBWorld/Mytheatre diseqc problem
How to get 99W G16 channels?
