Is Bluetooth working on the Joeys yet? | Page 4 | SatelliteGuys.US
i got mine from scott it is working right now listening to mash right now.i finally figured out to get it to work on the joey.
Reactions: TheKrell
I had the cell number to the Technician that initially came, so I called him to see if they have them. He said that they got them a couple of days ago. He said he hadn't installed one yet.
Bluegrass,
What did you have to figure out? Did you have to go into the Joey setup and do something?
i had to go to the settings where its says bluetooth all i did turn bluetooth on after i plugged in the bluetooth module then i paired the soundbar now its working.
Reactions: ChadT41
Tomorrow thanks to DISH I will be giving away a bunch of them! Check the other thread for details and you might be lucky enough to get one of your own. :)
Sling TV home setup
Cancelling Dish.....how long does it take?
