IPTV / FTA receiver | SatelliteGuys.US
IPTV / FTA receiver
glover31
271
24
Friendship New York
Is it possible to use openbox x3 firmware on openbox s9- s12 stb's. I see that all the boxes are linux based. So I wondered if the boxes were all the same. Would be nice to add youtube to my s9 or s10
Linux doesn't mean compatibility. Compare the flash size and tuner to make sure that they are the same. Bootloaders will be different. Likely that you would also need to get a remote as the key codes are probably different.
s9
*Chipset and Memory:
Chipset: Ali M3602
CPU: 396MHz
Flash: 4Mbytes
RAM: DDR2-1Gbit
*Tuner:
Twin Tuner PVR
Input Frequency:950~2150MHz
Loop Out Frequency:950~2150MHz
Input Level:-65~-25dBm
Input Impedance:75??
LNB Power: Auto/14v/18v/OFF, Imax = 500mA
x3
CPU: 396MHz MIPS dual core
Flash: 4Mbytes
Ram: DDR2400 128mb
clock spead 198mhz
*Tuner:
Single Tuner
DVB-S2 Standard
DVB-S2 demodulator
Input Frequency Range
950MHz~2150MHz
Input Signal Level
-25dBm ~ -65dBm
Demodulation
QPSK, 8PSK, 16APSK
Transport Stream
MPEG-2 ISO/IEC 13818 Transport Stream Specification
MPEG Profile Level
MPEG-2 SD, MPEG-2 HD, H.264/AVC SD, H.264/AVC HD
LNB Power & Polarisation
Vertical +13.5V, Horizontal 18V, Current: MAX 500ma
not looking like this will work
Motor & switch disecq set up
