iPhone App Issue? | SatelliteGuys.US
iPhone App Issue?
RawisTheGameHhH
SatelliteGuys Guru
135
Southside of Chicago, IL
Is anyone else's iPhone app not displaying the right channels. The only channels I can see are the ppv channels and such. I have my settings in the correct spot so it should show my channels only.
Best I can tell is they screwed up the recent upgrade (just like they usually do). I would imagine in a day or two you will be getting another iPhone App upgrade for the DTV scheduler. Same probelms here.
That didn't take them long to fix; kudos to DTV for fixing a great APP so fast. The DTV forum had walls of complaints about the flaw; guess they had no choice but to listen. :)
H20 reciever
ESPN HD GONE
