Neutron said:I sure wish I could get rid of the stocks app.
Had to let the install completely wipe my ipad and then I had to manually restore apps afterwards. Would not back up the device, and gave a generic error when trying to do so repeatedly.
Now I have 6 pages of apps to wade through rather than the 5-6 folders I had.
I had to do that the last 2 times I updated the software on my phone, due to space limitationsHad to let the install completely wipe my ipad and then I had to manually restore apps afterwards. Would not back up the device, and gave a generic error when trying to do so repeatedly.
Neutron said:Apple should have the installer check to see what apps you have, and then either tell you which apps are incompatible or better yet if there's an update to it from the very beginning, and offer to go get the updated app to reinstall on your device.
Apps in iTunes don't self update. Not sure why but just the way it is.
Sounds like an improvement Apple could do.![]()
Apparently I picked a bad time to buy a Apple Ipod Touch. My first.... maybe they solved all the issues prior to shipping it from China. Apple might let us "down grade" like Windows did for Vista. lol
I personally don't want the applications to auto update. I want to be able to decide when I download the application. You will have much more issues with applications being forced upon you than the couple of issues from apps with a new OS update.
That's why it should be an option on each app like it is on Android apps, not all or nothing.
Limited time offer
