Instant Weather Favorites List ??? | SatelliteGuys.US
Wylwrk
53
How do you remove a city / location from your favorites list on the Dish Interactive Instant Weather Favorites list?
I think I can help you.
With one of my receivers a #311, I have in the favorites list , room to load in 5 different cities as favorites.
The only way I could remove one of the cities from the list was to load it up to the maximum and try to add another one.
When the last city is added at the bottom of the list , the top city is erased.
It may mean erasing ones that you want to get to the one you don't want. Then you put them back in.
Slow, but it will erase a city.
On my 622, they usually disappear after a software download. I don't know, but a factory reset may get rid of them, as well as some of your other settings. Other than that, I don't see a way to just delete a city.
However, similar to what Clancy said....
Once I have a city in each spot and try to add another one on my 622, I get a prompt to select a city to be replace with the new city.
Slight change of subject: I use to like the AccuWeather, but for the past several weeks when I select CURRENT, there is too much buffalo manure on the screen to read the current conditions (not enough contrast). So between that and losing the settings each software download, I no longer find it useful nor use it. But the "Locals on the 8's" coming out in the future should be great.
Audio and Video not in Sync on 622
what dish network dish gets best signal for one satellite?
