but be sure to hammer a good foot of the pole flat because if you don't the concrete will not hold it great. I normally dry pack the concrete because we get so much rain that if I mix it, it does not harden great. Also take the ass end of a shovel or something and pack that concrete in there like you think it may be alive.
A few of us take the foot of a mast and take zinc screws and screw that joker on the bottom of the pole then when the concrete hardens that joker REALLY has something to hold to.
Why all that fuss. If your worried about air bubbles in the concrete just use a shop vac and hose "not the side that sucks" and use it like your churning butter. That will take care of air pockets. I will also say this, instead of buying zinc plated screws to put on the bottom of the pole to keep it from turning, Just invest that money in a heavier duty pole. Like well casing. If you get something thats a good 8 foot or more and bury it at least 4 feet its not going to turn inside hardened concrete. It definitely wont if you put concrete inside it. Ice in the winter is usually the culprit that gets between that pole and the concrete un ad-hearing the pole from the concrete. There is no room for the ice to expand to if there is concrete inside. Another thing I have seen people forgetting to do is put a flat rock on the bottom. Ice can push your pipe or 4x4 all over the darn place if you don't. Once the concrete has set for a while some oil based paint will help keep it sealed. Any cracked concrete is susceptible to water penetration. Thats why cracks in concrete get worse, ice expansion.
But if your dead set on putting screws in your pipe and such I would say skip the concrete altogether. Just torch 1/2 inch holes in the pipe all the way through, and put cut off pieces of re-bar or 1/2 inch pipe through the holes and weld them in place. Then just bury.
Maybe in the spring I will do a you tube video on what I just said above.
Excellent advice, and southern humor, lol. That thing on the shovel, though, I always called "the handle", hehe.I didn't read all the comments but be sure to hammer a good foot of the pole flat because if you don't the concrete will not hold it great. I normally dry pack the concrete because we get so much rain that if I mix it, it does not harden great. Also take the ass end of a shovel or something and pack that concrete in there like you think it may be alive.
Man the part with the screws to do what I was saying to do it works swimmingly but it still has to be flat. But you didn't catch what I was saying... Nor did I expect you to because I wrote that at 1 am. You really do need to flatten that joker or people ARE going to run into problems especially where I am from and get high winds all the time.
You can't just put a round pole in a round hole. That does not sound logical does it?
Limited time offer
