You could use the three-way splitter then connect the Joeys to the splitter, freeing up the client port then use a jumper cable between the two nodes. A Solo Node would be more ideal for the third Hopper but with the Duo Node at least you're prepared for a fourth Hopper if you ever wanted it. Make sure you have 75-ohm terminators on all unused node/splitter ports and good RG6 on all receivers with decent compression connectors on all ends. Also make sure any unnecessary splitters are taken out and that the necessary splitters are of good quality.
Sent from my iPhone 4S using Forum Runner
