installation questions | SatelliteGuys.US
Chris1523
16
Right now we have dish network,and we might be switching to directv. When the installer comes, will he be able to take the dish network dish off the roof? I was also wondering when returning the dish network receivers to dish, would I have to also return the lnbs back to dish? Thank you all for you help!
Sometimes DISH wants the LNB back.
Depending on what DISH dish you have, the Ka/Ku Dishes will fit on the larger DISH masts so there will be no addl holes. The smaller dishes will also interchange. The tech will want to use a DTV 18" but the masts and dishes will work.
DISH used better cable. Use it.
Joe
Gray bar on R22 when viewing locals
Super Bowl XLIII
