Indoor amplified antenna? | SatelliteGuys.US
mdovell
226
Would it be worth it to put in a amp for indoor one? I'm getting about two dozen channels roughly (that's including subchannels) with a indoor one from 30-35 miles away...not bad but I was curious as to getting more....
What else is around for you to get?
Check antennaweb.org
If you are getting good reception on the channels that you can receive, adding an amplifier could over drive the tuner for those stations, if you do try an amp I would also keep a variable attenuator in line adjust as needed!
Best antenna for 30+ miles?
Advice Needed
