Can someone tell me how I see which satellite a specific channel is on watching a program. It used to be on the info screen..thanks
While viewing the channel press the Info button then the Recall button.Can someone tell me how I see which satellite a specific channel is on watching a program. It used to be on the info screen..thanks
Pressing Info button twice does not work for me. I tried with a 40.0 & 54.0 remote control. Which remote are you using?Press the "Info" button twice while watching the channel.
When I get home I will try out my 20.0 remote. What Hopper model do you have? I am on H3I'm using a Logitech Harmony, but it works the same on my 20.0 remote.
I tried out my 21.0 on my H3, WJ, and 4KJ. Pressing the info button twice does not ID the satellite. Maybe it just works on the 211K equipment. Maybe the OP will let us know what equipment he has.When I get home I will try out my 20.0 remote. What Hopper model do you have? I am on H3
Thanks Dirtydan. Good info.On a Hopper3 press menu twice, go down to Dish click it, this way you get the Sat and the transponder.
Dan
Dan
Limited time offer
