I need help | SatelliteGuys.US
I need help
lalo_15
2
I need some information I have pansat 2500a I need help setting up my dish, I have a dish 500 and dishnetwork superdish the satellites I want to get is galaxy 4 at (99 W) and intelsat americas 13 (121 W) I would like to know which dish is better to get this satellite and also what's the LNB frequency. I'm in Tampa fl and my zip code is 33614
I guess your a music freak : ) The problem starts with Nimiq1 being a DBS satellite and G4 being an (FSS)KU satellite, so the dish 500 will work for Nimiq1 but you will need a KU band LNB and 30" dish for the G4 satellite (and a switch if you want), the spacing is not exactly right on the Dish 500 but that does not matter because of the above anyway. We have a FTA area here at SatelliteGuys.US and I am sure someone will move this thread there, you will find lots of useful info there!
Also the Dish 500 will not work if it has Dish Pro LNB.
http://www.lyngsat.com/nimiq1.html
http://www.lyngsat.com/g4r.html
Just did a POWER SCAN of G4R Nothing there FTA!
Dishnetwork and FTA configuration help...
Need Info to get Intelsat Americas 13
