Try pushing the format button on the dish remote. It sounds like it may be zoomed....
The bottom of the remote. The star button. That's format. Cycle thru till it looks right.
I was thinking the same thing, hopefully this works
No, i know about the star button. It's at normal view right now. I think the hd input to the receiver/house isn't as sharpe as it should be.
I've concluded that this is not a user error nor a signal error. I called the dish guy and he went through the signals and said it was good.
He's going to bring another receiver sat and see if it'll be clearer. It's either something wrong with the receiver or this is probably as good as it will get. Thus, i'll be disappointed with Dish.
On local channels, 2,3,4,7 etc, the HD channels are a little better than standard. With comcast, it was night and day.. huge difference. With dish, the pic quality is obviously only slightly better than standard for local channels. The HD HBO etc channels are better but not as sharp as what hd should be, but better than the HD local channels.
Have you tried making picture adjustments with the tv's picture controls? What's best for a cable signal is not necessarily best for a sat signal or dvd signal, etc....
The problem with the bolded is the signal going into the house is the same for EVERYONE. So either the Dish feed is truly terrible compared to your cable feed, and everyone here doesn't know what they're talking about, or you have some kind of issue (whether hardware or software based). I still suggest swapping receivers between your rooms and see if the problem follows the receiver or stays with your TV.No, i know about the star button. It's at normal view right now. I think the hd input to the receiver/house isn't as sharpe as it should be.
Limited time offer
