i just got a satellite dish fta ds2076 winegard standard ku lnbf 31" with | Page 2 | SatelliteGuys.US
what does plumb mean?
because i have the mount perfect level.and same the with the pole. just check them today!!
i enter the L O F , enter that info into the receiver.
? will the singal get though if the cable is in the way of the dish???
because when i adjust the skew , o being with the plug up, the cable is alittle in the way o the dish.
thanks or the help.
still trying! i sure hope i can get t5 or galaxy 10r .the main reason i bought this 31" winguard dish and pansat2500a receiver, was to get some thing ree to watch!
mainy the only channel 1 get here in this old valley is channel 3 pbs.and even that does not come in clear.
so far i put $202.00 usa cash into this, and have got nothing out of this fta!
WyrTwister said:
Untill you get this figured out , shoot for
AMC 5 79.0W 179.8 191.1 41.7 -0.2
As your due south sat .
Set the menue in the receiver to transponder 11742 or 11742000 frequency . Vertical polarity , Symbol Rate of 11110 or 11110000 , power on . Look at the label on the LNBF to see the L O F , enter that info into the receiver . Skew will be very close to zero . Dish will point to within 1.2 degrees of due south ( true ) or 11.1 degrees from magnetic south . Elevation 41.7 degrees . The mounting pipe MUST be plumb , both directions for these numbers to work .
Now scan that transponder / frequency & hopefully you will find
http://www.uen.org/
Utah Education Network .
Best of luck ,
Wyr
Bigger is ALWAYS better, but some slightly bigger dish do not work as well as the All American made Winegard dish!
i got T5 at el40.
and now am getting amc4 w4 both on ku band.
but i am only getting 1 channel on w4.
but i get a singal of 95 and up quatiy 24 and up on 6 tps.
pizza64er said:
i got T5 at el40.
Which sat is W4 ?
24 quality is pretty low . Tweek east - west , elevation , skew & depending pn the LNBF mount , the in - out adjustment of the LNBF .
Make sure the coax connectors are snug .
Double check what you typed in for LOF .
Forgot what kind of receiver you have . Did you do a blind scan ?
Wyr
Iceberg said:
W4 is the old name for AMC4
I keep getting tripped up on that . :-(
AMC 4 has some digital Ku , T 5 a bunch od digital Ku , most / much foreign language .
That is all I remember , been messing with C band for the last few monthas .
Wyr
i still can't get g10r ku band in:(
think i need a biger dish.
mainly when i had ac-band system i chould get all the c band birds.with a 10'
but not with a 7' dish.
Consider a Ku band dish for Ku ?
Wyr
Sat Mex problem
set up problem
