I have a Vip connected to a dispro 34 multiswitch to 3 big antenas what do I need to wire a Hopper | Page 2 | SatelliteGuys.US
110 and 119 from 1000.2 with new hybrid LNB and 129 from wing dish into port on the 1000.2.
He can't use a 1000.2.
He has two 8 footers for that.
Also the Hybrid only has one Input for wing dishes.
He would need a Hybrid LNB that had 3 wing dish inputs .
Sent from my SAMSUNG-SM-G900A using Tapatalk
The new Hybrid LNB for western arc already looks at all 3 satellites, 110, 119, 129... No need for a wing dish. And, he is way down deep into Mexico, he's not going to be able to use an H3....
Single DP LNB for each satellite
1 line out of each single DP LNB to a DPP 44 Switch w/Power Inserter
2 Lines out of the DPP 44 to a Solo Node then 1 Line to Hopper
Parts Needed
3 DP Single LNB's
1 DPP44 Multiswitch w/Power Inserter
1 Solo Node
*Compression F-Connectors PPC,Belden,Etc...
*Sweep Tested Solid Copper Cable @ 3Ghz
You may experiment running a Third Line to the DPP44 Switch from the Power Inserter to avoid signal loss and try to find Solid Copper Coaxial Cable Sweep Tested to 3Ghz for all your Cable runs
Hoppers are very picky on signal loss
For the Sling use a VPN
My 2 Pesos
Salu2 Panchocuerdas :devilish
Thanks Tecnicoloco but the same setup will work with a DPP33 instead of a 44 with power?
When you state picky on signal loss, means it will lose signal faster than my old Vip 722 in Mexico
Dish Network Renews ComScore contract
Moving to new house that already has a dish installed
