I have a question.... | SatelliteGuys.US
  • Thread starter Thread starter PalaHeel
  • Start date Start date
  • Replies Replies 0
  • Views Views 818
PalaHeel
62
When I run a system check on my both 622 and 722 DVRs I am getting an error message on Satellite 118. 119, 110 and 129 are fine. As you know the error message suggests that, in short, there could be weather related conditions , loose cables, dish out of alignment, etc.
When I run the point Dish check switch I am getting a good reception signal on 118 (between 60 and 70). I am also not having trouble getting any of the LILs or HD channels provided by 118.
I did have have to power down and re boot the 622 and that caused me to check the aforementioned.
My question is: Has there been a change regarding the 110? A CSR said be thought the 118 was not now in use for the 1000 + dish. Right or wrong?
Sorry for the long post but would appreciate some advice from you. Thanks in advance.
Hd Dvr
PBS, APTS Push FCC on Dish Network HD
