I ran the JB and within minutes it was done. Nothing to reconfigure, and everything works. Pretty simple and straightforward.
Sorry, I'm mocking someone...Same here.
Yes.Does iCloud still function fully? iTunes Match?
And is always the case with me every time I do it.Same here.
Yes.
JBing does not inhibit the normal functions of the phone. It simply opens up the phone to do more than Apple programmed it to do.
The charge on my JB phone last longer than the charge on my wife's unjailbroken phone. This is usually the case with every software update and JB even though I have more APPs installed. I just assumed it was because of the Cydia APPs I install that makes it easy for me to turn of features on the phone so it doesn't waste the battery.Has anyone else noticed improved battery life since JB?
I misunderstood what you were asking...my bad. Sometimes a JB may cause problems with some of the features with some people, just as sometimes software updates do the same. Usually there will be a Cydia update that corrects these issues.I googled it, and saw several reports of people having problems with iTunes Match after JB.
DO you have iTunes Match and iCloud enabled?
DodgerKing said:The charge on my JB phone last longer than the charge on my wife's unjailbroken phone. This is usually the case with every software update and JB even though I have more APPs installed. I just assumed it was because of the Cydia APPs I install that makes it easy for me to turn of features on the phone so it doesn't waste the battery.
Cydia is just add-on tools to enhance a JB phone. You can JB and *never* use Cydia.I misunderstood what you were asking...my bad. Sometimes a JB may cause problems with some of the features with some people, just as sometimes software updates do the same. Usually there will be a Cydia update that corrects these issues.
Since people have been reporting problems, then it is probably an issue that needs to be addressed for those that use it before they JB.
I would blame "user error"
Sent from my ADR6400L using Tapatalk
Just ignore what I quoted and was replying to...But to each their own.
Pepper said:First thing you want to do is add the www.pepper.net repo (mine) and install a little tweak called FakeClockUp. It reduces the animation delays and makes the phone feel faster.
Jailbreak QA is a good resource for lots of talk about it.
mywi is a must
Can you tell us how many countless hours you had to spend re-configuring your device after rooting/JB'ing it ? Also, what doesn't work now ? :neener
JB mine again yesterday, and added back some stuff that I missed. MyWy, IntelliScreenx, ect. There is a dialer that I was using before that I need to find again.
Worth doing IMO, and really easy to do, and undo.
Limited time offer
