HR54 picture glitches | SatelliteGuys.US
Jimbone21
11
Florida
Anybody else having issues with their 54 picture pixelating and glitching on HD channels? Mine just started doing this and it's doing it a lot.
Sent from my iPhone using SatelliteGuys mobile app
Check your signal strengths on 99ca/99cb/103ca/103cb, post back all transponder levels.
All the signal strengths are in the 90's. I know it's not that. All my other boxes are fine. When I ran a test it said primary tuner connection problem, but I know I don't have too many tuners. Sometimes when I run the test it says this other times it will say all items ok.
it might just be a tuner gone bad on the genie. i know the 44 you can press the guide and right arrow button on the front screen to pull up an extra menu, i think someone mentioned once you can do the same by pressing and holding menu button for like 5 seconds. that menu allows you to see if you have a dead tuner.
Anyone "moved" lately since AT&T took over?
Satellite Signal Meter, Best under $200?
