HR2X / R22 CE Release for the weekend of 12.4 v.384 | SatelliteGuys.US
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
Systems in this CE
HR20-100 • HR20-700
HR21-100 • HR21-200 • HR21-700
HR22-100 • R22-100 • R22-200
HR21Pro • HR23-700
Window of opportunity to download:
Friday, December 4, 2009 11:00PM - 2:30AM ET
Saturday, December 5, 2009 11:00PM - 2:30AM ET
Risk Level for this Download: High Risk
New features
  • None for this release
Improved/Updated
  • Under the hood
Notes
  • No keyword required for Multi-Room-Video activation. Keyword "LOSEMRV" will disable and "BRINGMRVBACK" will re-enable, but only until reboot.
  • This CE will remove your guide cache. Please allow up to 24 hrs to restore your full 14 day guide.
  • You will lose your guide cache when reverting from CE to national.
  • Please do not report sluggish issues within the first 12 hours of download
Previous Versions
New features
  • CE:21:01 (0x034D) - Left Menu appearance
  • CE:21:01 (0x034D) - Support for Linksys WET610N Wireless Adapter
  • CE:21:03 (0x353/0x354) - MRV is back!
  • CE:21:05 (0x035B) - New Playlist and Playlist sorting persistence
  • CE:21:05 (0x035B) - DIRECTV On DEMAND program detail screen facelift
  • CE:21:09 (0x036A) - MRV is back!
  • CE:21:10 (0x036F) - Unified Search
  • CE:21:10 (0x036F) - "Watch Now/Soon" from DIRECTV Cinema
  • CE:21:11 (0x0374) - Enriched Guide Data:
    • [*]Similar Shows
      [*]Cast & Crew
      [*]GUIDE Artwork
      [*]Actor Filmography
      [*]Actor Awards
      [*]Star ratings for movies
  • CE:21:12 (0x0379) - Smart Search now includes suggestions!
Improved/Updated
  • CE:21:01 (0x034D) Very High Risk
    • Playlist touch ups
    • Prioritizer renamed "Series Manager"
    • "Rec. Once" and "Rec. Series" text now more user friendly in To Do List and Guide
      • In the TO DO LIST for upcoming recordings:
        • Rec. Once is now Episode Options
        • Rec. Series is now Series Options
      • In the TO DO LIST for programs currently recording:
        • Rec. Once... is now Recording...
        • Rec. Series... is now Series Options
      • In the GUIDE for non-series-link programs:
        • Rec. Once is now Record Once
        • Rec. Series is now Record Series
    • Under the hood
  • CE:21:02 (0x0350) Very High Risk
    • [*]Under the hood
  • CE:21:03 (0x353/0x354) Very High Risk
    • [*]Under the hood
  • CE:21:04 (0x0356) Very High Risk
    • [*]Under the hood
  • CE:21:05 (0x035B) Very High Risk
    • [*]Under the hood
  • CE:21:06 (0x035F) SCARY HIGH RISK
    • [*]Under the hood
  • CE:21:07 (0x0364) Customer Candidate
    • [*]Under the hood
  • CE:21:08 (0x0368) Customer Candidate
    • [*]Under the hood
  • CE:21:09 (0x036A) Moderate Risk
    • [*]Media Share Improvements
      [*]Under the hood
  • CE:21:10 (0x036F) Moderate Risk
    • [*]Under the hood
  • CE:21:11 (0x0374) High Risk
    • [*]Quasi under the hood
      [*]Playlist Sort Order: Alphabetical sorting of folders now chronological within folder
  • CE:21:12 (0x0379) Very High Risk
    • [*]Under the hood
  • CE:21:13 (0x037E) High Risk
    • [*]Under the hood
      [*]Must reenter IAMANEDGECUTTER keyword to get Misc Options
  • CE:21:14 (0x0380) High Risk
    • [*]Under the hood
Finished on H23, HR20-100 & HR23-700.
I noticed there is a new (or at least I did not see it b4) item under location, called multi-room. Shows other DVRs networked for MVR. Does not show up on the H23, only the DVRs. All working well so far! I will have to do the HR21, when my wife is not watching it! ;)
Probably a problem with my network, not with the CE... new network. My downstairs HR22 wont get an IP, and for some reason my Linksys is only giving it one for 60 seconds (i can see it counting down from 60 seconds in the DHCP clients table). Meanwhile everything else that is connected is fine. Just can't get anything but the default 169 IP.
Just strange, it's picking up the mac address of my HR22, but not the name of it, like my other HR22 that says DirecTV-HR22-gibberish.
HR21 updated. Tried H23 a dozen times and it will not look for software. I am going to try unplugging it for a while.
Ok, starting downloading now.....had to wait for the UFC to finish...can't believe that big fat Roy Nelson won....
Update, have it on both HR2*'s so far so good....
Seems to be a good stable one, remote response is much better than last week, less double entries or delayed entries.
I was actually going to say the opposite, at least for my HR23. Much slower response than the last CE. The others seem about the same. Today, my HR23 actually seemed to lock up, taking no input from the remote or front panel, while still having a picture. A RBR fixed the issue, however the response time is still quite slow.
H21/H23 CE Release for the weekend of 12.4
D11-800 / D12 CE Release for 12/11
