I have been on vacation the last week and have missed the last 2 CE's. Doesn't sound like I have missed much though.
I put the CE on both of my DVR's and the play list on the family room won't stay on A-Z it always goes back to sort by date, got any solutions?
DK:20090713-24B6
HR21-100
i will have to go back to the national release for the 5th ween in a row. still having major issues with guide scrolling with this ce. makes viewing impossible so i have no choice. haven't noticed any other issues.
Explain your self Rey,
Guide scrolling, going to the guide and looking for a show ...
What is the Viewing impossible part ?
Jimbo
Got a weird one, had lots of problems today and one of then is that I'm missing the "Send Report" option on my HR23, it's there on all the HR20s.
It's just plain gone...
HR21-700
DK 20090714-1E58
After downloading this CE on Friday night, I noticed that the number of shows in my TODO list was quite a bit lower than normal. I thought that it might be due to reloading the guide data after the software update, although this has never happened with prior CE downloads.
By Saturday afternoon, I still had the same low number of shows in the TODO list. In the prioritizer, the series links did not show the correct number of episodes available. I deleted one of the series links and then added it back again. The series link was set to record both first run and repeat episodes. It did not pick up all of the episodes for recording that were available in the guide.
Shows that have been recorded since Friday have dropped off the TODO list, but no new episodes have been added. If I go into the guide, select one of the missing episodes and press the record button once, the series link icon will appear, the episode is added to the TODO list and the TODO list count increases.
I have not tried a RBR yet to see if that will correct the problem. I will try later after tonight's shows are recorded and report back with any results.
mc2739m you're not alone, looks like the CE's broke the to do function. You need to delete your series link and readd it and that should fix it. If not you'll need to do two reboots right in a row to force the box to dump the cached guide data and start from scratch and then redo the SL's again. Just one of the chances you take with the CE's, sh*t happens.
Today is the first time I've seen the real laggy remote others have experienced; I had been getting away with running system test to eliminate some problems, but I may try the double reboot tomorrow if things are still extremely slow.
My ToDo List is small as others have reported but I don't think I've missed any recordings yet but I'll have to watch to see if the ToDo List is maintaining itself.
Has anyone had any MRV Server shutdowns with this CE?
I thought I had one this morning when I was unable to view MRV content from L/R Server but I found that HR22 had went to NA-NA Land and had to RBR to to get it back to reality. Had to run system test to get MRV servers going after that.
Not sure what happened to get the L/R HR22 hung-up like that; I had been watching it and put it in standby and found it hung-up the next morning. The disk was spinning like it was doing something but not responding to remote or front panel to power-on for viewing.
Sent Report # 20090714-27B7 from L/R HR22.
Didnt get a chance to talk about it yesterday, but for the 3rd straight week, my MRV went dead on monday afternoon, 2.5 days after the CE load.
I changed out everything in the network late last week just to be sure. All that remained the same was the receivers and the router giving them DHCP/etc. Switch and wiring are new.
HR21-100 with AM21
Send report option is gone for the second week. Tried all of the usual stuff to bring it back. Have a good connection to the internet and can use VOD.
Recordings are being missed and are not showing up in To Do List.
Extremely slow scrolling through the guide.
I have had to go back to the National Release since recordings are being missed with this CE.
Rob,
By chance, are your recordings in your "History" folder ?
If so, you may be able to watch them from there, that doesn't fix the problem, but you may have them recorded none the less.
Limited time offer
