HR24 problem? | SatelliteGuys.US
HR24 problem?
airhead13
18
have whole home dvr pk single wire swm dish,1 hd dvr,2 d-12 w/bpf and 1 hr24 that I can,t get to work without freezing and pixels.have moved hr24 to another location in home and still does same thing,have run new cable from swm switch to hr24 and same problem,have replaced all connectors,have moved this hdhr24 rvc to power inserter and same problem.also have replaced hr24 with another hr24 and same problem occurs.I have tried everything I can thing of,even unpluged the 2 d-12 and only have both hd boxes connected.have run a new cable from dish to swm switch.don,t know what else to try.?all other boxes are working just fine ,the HR24 is problem rvc.have deactivated and reactivate still freezing.signal is 95 and above all tps.
The HR24 IS the HD-DVR.. You mean the H24 (HD non-DVR)?
If the problem persists even with a new box, you have a bad LNB. Been there, done that. Except my problem jumped around between TV's. But otherwise that's exactly what happened to me.
yes a non-drv hd rvc,thanks for the info,will order another swm lnb.
did a local channel go hd
SWM8 and 10 tuners?
