HR24 / H24 CE Release 7/23 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE
H24-100 • H24-700
HR24-100 • HR24-500
Window of opportunity to download:
Friday, July 23, 2010 11:00PM - 2:30AM ET
Saturday, July 24, 2010 11:00PM - 2:30AM ET
Risk Level for this Download:
H24 Moderate Risk
HR24 Low Risk
New features
None for the release
Improved/Updated
Under the hood
Notes
For all Hx24 MRV testing, please use SWM/MoCA.
If the box goes into standby during software download, please take the box out of standby using remote power button and complete the download. Report any download issues.
Please send logs along with all reports, including MRV issues.
When reporting issues, if feasible please send the log while the box is in the problematic state. In addition, please provide context around when the log was sent.
If feasible, when reporting issues, please indicate if these issues are seen on HR2x/H2x.
Please do not report sluggish issues or missing search results within the first 12 hours after download.
If you revert from CE back to National x3E0, you will lose the guide cache, recordings made after CE, recordings played back since CE, Series Manager entries and the To Do list.
Channel logos will be unavailable for the first hour after download and require IAMANEDGECUTTER to be enabled.
This CE may remove your guide cache. Please allow up to 24 hrs to restore your full 7 day guide.
Version History
"Under-the-hood" and "stability" improvements are expected with every release and are not noted here.
New features
CE:03:01(0x03E8) [HR24 only]
Posters everywhere!
DirecTV Cinema enhancements.
CE:03:05(0x03EB) [HR24 only]
Smart Search now gives Top Matches
Improved/Updated
CE:03:07(0x03E3/0x03F8)
MRV (all but HR24-100)
System Test (all but HR24-100)
Done HR24. Done H24
Jimbo. I will trade that Tstorm for this heat wave we been having. It appears to rain all around us, but were missing it all.
Done HR24. Done H24
Sounds like you right here with us, we've been missing the storms for the most part, till tonight.
90-95 most of the week with humidity around 80%.
Fortunately last night when the rains finally did get here the temps dropped to around 75* which actually made it nice for awhile.
Alot of the rains tend to go right above us like last night for a good part of it or go right below us, so they are always telling us were gonna get the rain, but often don't.
I like the storms, but I'd much rather get my painting done.
First CE Experience
Tonight was my first CE download experience. I was quite excited and nervous at the same time. I noticed a whole bunch of extra numbers between a typical restart (unfortunately, in the week since I have had the box, I have had numerous occasions to complete reboots). Also, downloading the data took a considerable amount of time, compared, again, to a typical reboot. Of course, this makes sense as I was downloading essentially a new operating system for my HR24-100.
Overall, the download went flawlessly. No issues or concerns to report at this time.
Welcome to the CE fun.
I'm guessing you've read all the info available here before hand.
It is normal for the D/L to take quite a bit longer to load as it will download the new software, then activate it, then reboot the box, so the difference is the D/L time .
Does Direct Receiver Auto update or do yo have to manually update them??
Both .....
D*'s recvrs get updates automatically when D* decides to send them.
In the CE process, you manually download the update.
Info in the first several pages explaining the CE process.
Both .....
Where do you go in the menu to do the manual updates for the CE??
H24 CE Release 7/9
H23 CE Release 7/30
