HR22 wont recognize AM21 | SatelliteGuys.US
AM21 ota tuner problems
I connected my am21 to my HR22-100 correctly but can't scan for channels to set it up. I tried entering the zip codes for my off air channels and the edit channel is not highlighted and you can't click on it with the remote.I tried another am21 tuner with the same results.I have updated the software on my HR22-100 and tried two diffrent usb plugs with the same results.The AM21 doen't show up on the hr22-100 as being connected. I have talked to three different Directv Techs and they don't have a clue of what the problem is. I think it might be a bad usb on my HR22-100 but I don't know how to check it. Directv wants $50. to send a Tech to check it out. Does anyone know what my problem might be?
Do you have a cell phone? Try using the usb on the dvr to charge it. That should tell you if the port is working or not.
You couldn't have set up the zip codes if the dvr was not recognizing the AM21, because unless the AM21 is connected you do not have any antenna options. I was going to suggest you check all your antenna connections,because unless the AM21 is receiving a signal from the antenna you will not see any of the OTA channels. I just had to go 40 feet back up on the roof because I screwed up a crimp connection, of course it had to be the one on the antenna and not one I could get to from the ground.
XBOX One
HR34 vs. HR44
