HR20-700 & HR21-100 0x0245 CE Release 6/6 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE / Version
HR21-100 {CE:14:07} 0x0245
HR20-700 {CE:14:07} 0x0245
Window of opportunity to download:
Friday, June 6, 2008 11:00PM - 2:30AM ET
Saturday, June 7, 2008 11:00PM - 2:30AM ET
PLEASE READ THIS FIRST! CE Release Warnings & Agreement
PLEASE READ THIS SECOND! CE Release Download Instructions
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the CE Chat on Friday nights:
cechat.satelliteguys.us
Improved
  • 01 - Stability
  • 01 - Accurate network connection status after reboot
  • 01 - Overall Media Share
  • 01 - Channel change speed
  • 01 - Tuning and Recording Robustness
  • 02 - Stability
  • 02 - Fixed incorrect blue background
  • 02 - Fixed R icon not displaying in Folder during recording of a event in Folder
  • 02 - Fixed unable to Clear Delete Marks in Folders in Mark And Delete Screen
  • 02 - Fixed unable to modify extension on single episode of a booked series
  • 02 - Fixed modifying extension of already booked series does not update episodes already in ToDo
  • 02 - Fixed black screen shown when blackout is removed
  • 02 - Fixed no Kepp or Delete On Screen Display OSD after FF4 to end, RW, Pause, then Advanced
  • 02 - Tuning Robustness
  • 02 - MediaShare – Fixed unable to play slideshow in PIG when browsing thumbnail
  • 02 - MediaShare – Fixed wrong song ordering
  • 02 - MediaShare – Fixed blank thumbnails
  • 02 - MediaShare – Fixed FF of pictures jumps back instead
  • 02 - MediaShare - Stability
  • 03 - Fixed channel banner program information being incorrect after using previous button
  • 03 - Stability improvements, including issue after deleting in response to K/D OSD.
  • 03 - Fixed recently searched keyword not saved in previous screen
  • 04 – Fixed stuck boot 1 of 2
  • 04 – Recurring manual records no longer share playlist folder
  • 04 – Faster deleting large folder from playlist
  • 04 – Improved history for manual records
  • 04 – Stability improvements
  • 04 – Fixed DIRECTV On Demand results list
  • 04 – Fixed issue where KEEP ICON is missing after using mark&delete
  • 04 – Fixed mini-guide with guide tip
  • 04 – Lipsync improvement
  • 04 – Media Share Stability
  • 05 - Added ability to send a Diagnostics Report back to DIRECTV - See notes
  • 05 - Added New Release category for DIRECTV on Demand homepage
  • 06 – Stability
  • 06 – Audio
  • 06 - Mediashare compatibility with Nero MediaHome
  • 07 - Recording robustness
  • 07 - Favorite List handling of hidden ATSC channels
  • 07 - Auto-recording titles with symbols e.g. Law & Order
  • 07 - Mediashare media access issues
  • 07 - Removed HDCP warning during HDMI negotiation
Updated
  • 01 - History messages for recording and deletion events
  • 01 - Close Captioning Left Placement
  • 05 - PC Mediashare is back
  • 05 - Faster category search and sort
  • 05 - Faster loading DIRECTV on Demand listing
  • 05 - Program Info Screen text
  • 05 - Stability
  • 07 - GameSearch
  • 07 - User Interface various issues addressed
  • 07 - Installer Dish Setup
  • 07 - Issues with rebooting
New features
  • 01 - Triple Tap support e.g. title/name/keyword search screens, favorite list naming, etc
  • 01 - Search for PPV Movies in guide options panel
  • 02 - 1-touch record hint for program cells/items
  • 02 - Add "Move to Top" hint OSD in the Prioritizer screen
  • 02 - Add a display settings option in the System Setup screen for the enabling/disabling of the 1-touch Record Tip OSD
  • 03 - Daily Fortune
Notes
  • 01 - This CE cycle is expected to contain new features
  • 04 – THIS DOWNLOAD WILL REMOVE GUIDE CACHE AND THE GUIDE ACQUISITION WILL TAKE LONGER
  • 04 – BOOT STUCK WARNING: If you could not boot with the last CE with network attached, and had to revert to national to be able to boot with network, do not try POKEEYENOW. If you try it, your HR20 will probably still hang/crash on boot. If you insist, then you will have to boot without your network and POKEEYELATER to correct.
  • 05 - Send Diagnostics Report:
    requires IAMANEDGECUTTER keyword search to be enabled
    *** Network must be properly set up and working to use this feature ***
    1. [*]Use the Menu+Info keys to get to the Misc Options screen
      [*]Select the Report option
      [*]Click on Send
      [*]Wait for it to finish
      [*]You will receive a confirmation key in your response.
      *** Please include this key in any post you make in the issues thread ***
      [*]Please note that you can only send one report per 24 hours
      [*]If you do not have a network connection, you will not have this option
  • 06 - sync'd with HR20-700 CE cycle
  • 07 - Evaluating amber record light again
PLEASE NOTE: The HR21-200 & HR21-700 have been removed from this cycle.
A different thread has a "national release canidate" update for this weekend.
So after a reboot your recordings are still there?
Hdtvtechno - did you try a reboot to see if the others came back?
I missed this cycle due to major storms - had no signal last night and after an our of trying I gave up and went to bed. Today I played "dodge the tornado"then spent some time hooking my generator up to a close friends houe - power is out almost everywhere but my road.
I never had ANY problem with this d/l as far as losing recordings, matter of fact, I have not had any trouble with this d/l at all., even my CID is working !
Jimbo
Yeah and watchable also... also finally got my mediashare working and working good...:)
On the mediashare. is it just the playing vids and music from a pc or is the feature that allowes you to watch recording on a second hr21 in another room?
Well, turns out one of my HR20's did receive 0x0245 through the storms Saturday night.
Monday it became stuck in "Acquiring guide data". The message would not go away on live programming, but did go away on recorded programming.
I left it for 24 hours - never went away.
Tuesday I rebooted and the message is gone.
OK, just had an issue with my receiver that I'm reporting in the CE thread as well as the widget thread.
Watching a recording of the Braves vs. Cubs from 6/11 on channel 206 - ESPN (MPEG2 HD) Hit the right button to test the widget bar and the screen went black, then the widget bar opened. Close the widget bar, screen stayed black. Audio continued. I hit info and play, both showed the info or timebar as usual. I toggled to the previous channel and video came back. Toggled back to the recording and the video played as normal.
D11-300 {CE:09:05} 0x110A -- 6/9 Special One Night Release
Have you checked your WIDGET lately?
