How to Upgrade the LNB on a Direcway/PWay dish | SatelliteGuys.US
snathanb
2,580
4
DFW
Note to mods: Perhaps this belongs in the FAQ area, perhaps not. It's not going to be a review, but simply instructional.
This post will contain information on how I upgraded the LNB on my Direcway dish. The instructions will be similar for upgrading a Primestar dish, as well. This topic comes up often, so I thought it would be beneficial to post a few pictures from my upgrade process.
Background
I use an old Direcway dish for FTA. It is motorized, and I hand-built the mount from an old 18" DTV dish mount. Two reasons for this. 1) to reduce the weight on the motor. 2) So it would fit the motor mount.
The direcway dish I use has a seperate feedhorn and lbnf. This is different from what you see on most DBS system and many FTA systems. They use an LNBF which is a feedhorn and an LNB combined into a single small unit.
The LNB and Feedhorn are connected by a C-120 flange connector. Fortunately, this is a much-used standard connector that will allow the LNB portion to be upgraded, while retaining the feedhorn.
The LNBs from most Direcway and Primestar dishes are in the .6 Db range. Also, some older Primestar LNBs had seperate connections for V and H, making them more difficult to use.
Newer LNBs, such as the SNF-041, are made with a C-120 Flange, to be directly connected to these types of systems. They are .3 Db LNBs, providing the same signal quality as their much review cousins the SNH-031.
In the posts after this I will be posting pictures, with narrative.
The Original Dish
This is a photo of the original dish. Notice the big white box at the end of the feedarm. That is called the LNB shroud. The Feedhorn and the LNB itself are concealed within that box.
It is easily removed with a few screws.
Dish with Shroud Removed
This is the dish with the LNB Shroud removed.
The white piece at the very end is the LNB. It is connected with 4 machine screws to the Feedhorn, the long, narrow, grey metal tube.
The LNB and Feedhorn are securely mounted to the dish with 2 machine screws.
Close Up view of LNB
This is a close up view of the LNB mounted to the feedhorn.
You can clearly see the machine screws that mount the LNB to the feedhorn
Picture of Removed LNB
This is a picture of the removed LNB sitting on a scale, so you can see the weight.
Of note are the 8 mounting holes. This is typical, if not standard, for a C-120 connector. If you look at the picture before, you will see the DWAY Feedhorn only uses 4 of the 8 holes for mounting.
Also noticed the rubber o-ring. Also typical of C-120 flange connections, and seals water from entering the LNB.
Snf-041
This picture shows the contents of the box of the replacement LNB, and invacom SNF-041.
Has a detailed instruction sheet, the LNB, weather-proof connectors, 8 brass screws, and the rubber o-ring.
Weight Comparison
This picture shows the weight of the SNF-041. Notice it is about 10% heavier than the old direcway LNB.
LNB Comparison Pictures
The direcway and invacom LNB are very differently shaped.
Here are a few comparison pictures.
Installing the LNB
Installing the LNB is very, very simple. It was simply a matter of removing the 4 machine screws that held on the old one, and bolting on the new LNB (making sure to install the rubber o-ring).
Note: I elected not to use the screws that came with the LNB, and used the 4 machine screws from the original setup. They were stainless steel and very high quality compared to the ones that came with the SNF-041.
Picture is of the Dish with the SNF-041 installed.
Replacing the Shround
Well... that's a complicated issue.
Because of the difference in size the LNB shround does not fit.
See pic.
My original plan was to cut a notch in the shroud to fit around the end of the SNF-041.
However, that would still leave the connector exposed, as it is at the very end.
So, in the end, I decided to seal all connections, and leave it shroudless.
Final Words
The upgrade is a quick, easy process. Discounting the time it took to take the pictures, it was a 15 minute job, at best.
There are plenty of reviews around already on the benefits and results of upgrading to an Invacom SNH/SNF-041, so I will defer to those, rather than repeat their results.
I hope you found these instructions and pictures of some use.
In a final shameless plug, I want to thank forum moderator PSB for providing the SNF-041 at a great price, which is publically available to all at:
http://www.psbsatellite.com/
AWESOME!!! :clap :clap :clap
Very well done!
I have the same setup for DirecPC, but I have a DBS LNB next to the KU band. Might have to do this too :)
(just have to get the LNB from Pete :)
I have a DBS LNB there, as well, I just removed it for the pictures.
When using the shroud, I was using industrial-strength velcro to hold it on (worked great!),
Without the shround, I simply have it zip-tied next to it. Works like a charm!
Not 100% true, I charge English customers more :D
Great work snathanb!
Remove Diseqc...signal goes up??
Galaxy 10 Reception
