dwarren2 SatelliteGuys Pro Pub Member / Supporter Oct 30, 2003 4,076 287 Rochester, NY Region Apr 15, 2014 #41 It does. You select which one you want to access.
darrengs SatelliteGuys Pro May 13, 2012 657 199 NJ Apr 16, 2014 #42 dwarren2 said: It does. You select which one you want to access. Click to expand... NYDutch said: I only have one Hopper, so I'm not sure, but I think the Dish Anywhere app would give you recording access to both Hoppers. Click to expand... Wouldn't both Hoppers need sling? I have one Hopper with sling, and one regular Hopper.
dare2be SatelliteGuys God Lifetime Supporter Jul 15, 2011 12,743 7,776 FL Apr 16, 2014 #43 darrengs said: Wouldn't both Hoppers need sling? I have one Hopper with sling, and one regular Hopper. Click to expand... Nope, I can set timers on my non-sling 722 using Dish Anywhere just fine.
Scherrman SatelliteGuys Master Supporting Founder Mar 14, 2008 15,555 9,951 Eastern Iowa Apr 16, 2014 #44 darrengs said: Wouldn't both Hoppers need sling? I have one Hopper with sling, and one regular Hopper. Click to expand... Sling is not needed to set recordings, only for remote viewing. I'm not even sure if you need the receivers connected to the internet to set recordings. I believe it just does it through the satellite signal.
patmurphey SatelliteGuys Pro Dec 29, 2006 1,297 442 New Jersey Apr 16, 2014 #45 An extra Joey is cheaper than a mobile device... ...and accessible from a comfortable chair without getting up.
TheKrell A mighty and noble race originating on Altair IV. Pub Member / Supporter Jan 4, 2007 39,069 47,083 Fairfax, VA Apr 16, 2014 #46 patmurphey said: An extra Joey is cheaper than a mobile device... Click to expand... Only for a few months, and thereafter you might as well buy the mobile device and avoid the $7/mo charge that you get with a Joey in perpetuity.
