I have a TelStar 5 satellite dish, and it picks up a lot of international channels. I want to keep the international channels and receive local US channels like PBS, NBC, ABC, and CBS. How can i do this? Some help would be great.
correct. a simple diseqc switch can combine the 2 dishes so you can flip between channels no issuesif i get a 2nd dish won't i need another receiver, too?
yesWould a C-Band dish pick up PBS, NBC and TelStar int'l channels at the same time?
depends on the dish but normally yes you can add a motor to the existing dish. The reason I say it depends is I've seen some dishes where major modifying of the brackets is required to make it work. Most the bracket just slips right on the motor shaftCan i add a motor to my dish, or do i need a whole new motorized dish? How does that work?
yes. Once its all set up and aimed properly when you change channels if its on a different satellite the motor will move to the right locationDo i input the position of the dish into it and it automatically moves to that location?
Iceberg said:
Iceberg said:depends on the dish but normally yes you can add a motor to the existing dish. The reason I say it depends is I've seen some dishes where major modifying of the brackets is required to make it work. Most the bracket just slips right on the motor shaft
Iceberg said:yes. Once its all set up and aimed properly when you change channels if its on a different satellite the motor will move to the right location
Limited time offer
