There are plenty of settings for diseqc on the azbox. From what I see there is
Diseqc 1.0 & Diseqc 1.1 along with 22K settings. I dont see a separate Diseqc 1.1 dropdown so I think the max you can do is 16 (Diseqc 1.1 + 22k switches)
Someone correct me if I am wrong. I only have 6 LNB's set up (Diseqc 1.0 & 22k switches)
Linuxman, please pick up the purple phone....Linuxman...you are needed in this thread...please pick up the purple phone.![]()
Yea, but that hardly tells the whole story.I have 28 lnbfs hooked to mine using 4x4 multi-switchres (22Khz on and off), 4X1 diseqc switches leading into 8X1 diseqc switches, and planning to add more.![]()
If you keep going in the Diseqc selection menu, you find "combination mode" where you can combine committed and uncommitted Diseqc switches.
That should give you 64 lnbf's .
It's a long way in using the right arrow. Probably the left arrow is a shorter route.
Limited time offer
