How many channels on a spotbeam? | SatelliteGuys.US
Dune
SatelliteGuys Guru
145
Kailua Kona, HI
Does anyone know about how many channels can be put on a spot beam?
Dish has a new beam pointed to Hawaii from the 110 sat TP23 but I don't think they are showing anything yet.
We currently get our locals from the 119 sat spot beam.
I'm wondering if they might make some HD channels available.
Thanks, Dune
it's the same as any TP
They usually set the limit to 12 SD channels
4 MPEG4 HD channels
so it depends how many tps are in the beam
if there are 2 tps in the beam then 24 sd channels, and so forth, get it?
Does changing the skew on a DishPro 500 change the look angle?
322 dead
