How do I Perform a Factory Reset on a 508? | SatelliteGuys.US
Hold the front panel power button down.
Another is to g to menue and then into the system info screen and power down the receiver then pull the power cord and wait 60 seconds then plug it back in.
A third is to pull the smart card then reinsert it after 10 seconds.
Thanks - I am quite familiar with all these procedures. I am looking to factory reset the whole receiver. i.e. wipe out the hard drive and reset all settings and re-download all software
Thanks but the code sequence in that thread does not work on a 508. Does anyone out there know the correct code?
It does work but you need to then uplug the 508. Just recenctly did this on a 508 I sold. Could not figure it out, so I unplugged it. Then after bootup all was reset with no recordings.
Question re: Dish Mover
Adding a third receiver
