I hit stop in the middle of it, and it reset. That should have stopped it right? It's S528 still.
Thanks for the feedback, I was curious and figured there was a good reasonI deleted it, because depending on the hardware version of your Hopper you may never get another software update again.
And DISH will not support you unless you are a DISH employee as it was not meant for non employees.
Can you revert back if you don't like it?
No you can not revert, and its quite possible (due to a bug) you may not get another software update to download.![]()
Thanks for telling us this. I was thinking about trying it out, but I think I'll just wait 2 more weeks and upgrade to the H3.No you can not revert, and its quite possible (due to a bug) you may not get another software update to download.![]()
Thanks for telling us this. I was thinking about trying it out but I think I'll just wait 2 more weeks and upgrade to the H3.
It is downloading now to one of my HWSs that I use just for auto racing. I will play with it to get use to the interface before auto racing seasons start back up.If your going to upgrade for sure to H3, dont mind the bugs for 2 weeks.. i say go for it.. give you time to get use to interface
Not a problem if it does.I hope it doesn't cause you any issues. The version of the software you will get is real real old as well.
Well if the upgrade is only $150 then I'll go for it, but if it's $350 then that may be too high for me.If your going to upgrade for sure to H3, dont mind the bugs for 2 weeks.. i say go for it.. give you time to get use to interface
They changed the pricing today... the top price now is $150.Well if the upgrade is only $150 then I'll go for it, but if it's $350 then that may be too high for me.
So the most an H3 upgrade will cost is $150 for existing users?They changed the pricing today... the top price now is $150.![]()
Correct, plus the cost of the truck roll.So the most an H3 upgrade will cost is $150 for existing users?
Can you explain what you people are talking about this software version...How do I get it and why don't I want it?Also note that if you do they upgrade your EHD's may not work. The version that was sent to the employees is really an old version now.
If I hear its safe to upgrade I will let you know, but I dont want to see anyone kill their Hopper and be stuck since DISH will not support you.
Limited time offer
