Hopper Standby | SatelliteGuys.US
Hopper Standby
DFPope
38
Alabama
Since the last software update my Hopper goes into standby even after the guide update. I turn it back on after the guide update finishes and it will standby 2 or 3 more times after that.
Anyone else experience this ?
You may need to go to
Yellow+Diagnostics+Updates and set Disable vs. 2 to 8 hours.
This does not do inactivity so you must do so manually.
-Ken
Thanks but the inactivity timer has always been disabled. Never experienced this until S418. Have had this hopper for almost 2 years.
Since 418 and only after the guide update it will standby a couple of times about 30 min apart. Just goes into standby, no warning. After that all is fine until the next guide update.
No big deal I was just wondering if anyone else had seen this since 418.
Joey loosing sync with Hopper for split second
8 New HD Local Markets coming to DISH
