Hopper & Harmony 880 Remote Problems | Page 2 | SatelliteGuys.US
Yes I tried a search and read the other thread. If you use the toggle does it shut the receiver off on power down? Mine doesn't under its current configuration. I tried setting it up for discrete codes, but it doesn't shut down. I will try the togle I guess. I can always change it back.
My Harmony One shuts off the Hopper using Power Toggle, Discrete Power Off, or the main activity Power Off button. The same goes for my Joey with my Harmony 650.
Most of the info in this thread is now out dated. Hopper profile now has a full set of commands including discretes. To solve the power issue, answer the questions correctly in the setup wizard (device has seperate commands for on and off) and in device setup choose turn off when not used.
I changed it to power toggle and now it is shutting off properly. I believe I had it set up for discrete commands and turn off when not used, but it didn't. Now it does so I'll stick with that I guess. Thanks for all the helpful information.
Can you format the hard drive in a VIP 922 and or Hopper?
connecting Hopper online questions
