Hopper and the Slingbox Pro HD | SatelliteGuys.US
doltonjn
16
Claremore, OK
Why does Sling not showing any supoort for the Hopper using a Slingbox Pro HD. You think they would at least have the hopper remote loaded by now.
The Hopper remote is UHF which is why its not listed by the Sling software. Instead use the 722K remote (which even gives you the colored buttons) and make sure IR remote support is turned on in the Hopper settings.)
Hank :D
Switching channels prior to recording
One time Epix Credit?
