Hopper 3 folder? | Page 2 | SatelliteGuys.US
Hopper 3 folder?
If you are thinking that the episodes grouped together under a program name are a "folder" then no, you can't change that. Real "Folders" are something you create and you either move recordings to them, or in "timers", you direct new recordings to default to t
If you are thinking that the episodes grouped together under a program name are a "folder" then no, you can't change that. Real "Folders" are something you create and you either move recordings to them, or in "timers", you direct new recordings to default to those created folders.
got it thanks
Hopper 3 Start-up
bought hopper 3
