Hopper 3 Arctic circle set up. | Page 5 | SatelliteGuys.US
From time to time it would get past the switch setup screen and move to finding satellite signal. I don't know if it was just tricking the system out or what but I'm gonna play with it a little bit now and see if I can figure something out while it's still together with the current parts.
I'd probably still take someone up on LNB just gotta figure out if it would hook up to the dish the same.
Reactions: pattykay
Good catch, Bobby! As TheKrell said, that would act as a legacy Dish LNB, so it would not be compatible with the newer Dish Pro switches at all.
I can't zoom in far enough to read the model number (if it is shown at all on one of the stickers on top of the receiver) but that is either a 301 or a 311, as TheKrell said. If it is a 311, then it may still work for those free channels, if that is the correct Smart Card for the receiver shown in the picture. If it is a 301, then Dish no longer broadcasts in a format that it will support, so it should be taken to a recycler for proper disposal.
Okay, I remembered that there are a couple of other possible models for that old receiver, either of which would explain the separator. It could be a 322. That is a dual-tuner standard-def receiver for two TV's. It would still require a Dish Pro LNB to be able to use the separator with a single cable from the LNB. Otherwise, it would need two cables from the legacy LNB.
The other possibility is that it is a 311k. This is a receiver that was originally manufactured as a 322, but then Dish bastardized it to be able to use it as a replacement for the 301, when they were running out of stock on 311's. On the 311k, the TV2 output is disabled, so it only acts as a single-tuner receiver for one TV. It was intended to only need one cable from the LNB to one of the satellite inputs on the back of the receiver. However, after the 311k came out, some people started complaining that the receiver was giving them problems because it did not have a satellite signal on both tuners, even though you could actually only use one of the tuners. So, Dish started installing them with separators so that both tuners would have signal, to keep the receiver happy. Dish did not keep installing this model for very long after that.
Reactions: TheKrell
It was a receiver someone brought up to try. They were able to get the free channels at one point but them soemthing with the card happen apparently from what I've been told.
Still, it is a receiver that you could try hooking up to that "legacy" (Directv) LNB, to see if you actually have a satellite signal. (Make sure it is not a 301 first. All of the other models that I listed will still work, as long as you have two cables from the LNB to the dual-tuner models.) Even if you can't actually receive any channels, it should still be able to show you the signal strength reading, and take a guide download. After verifying that you have good signal strength, you can change the LNB to a Dish Pro LNB, and move a cable back over to the DPH42 switch to hook up the Hopper 3.
Reactions: TheKrell
Okay, I did run a direct line in once. I don't believe it's the correct card it was giving me some sort of error.
like a receiver not set up error and wouldn't let me get to the signal set up area. It's sounding like I may have a couple hours down time so I'll go ahead and give it a look through tomorrow and see what I can do.
if it doesn't do anything I'll just continue to poke around with the Sat Signal finder until I can get something. I might look into a better signal finder. With winter storms in the area a lot of times tour dish can get moved slightly.
One thing, you are correct about that dish only hitting one Sat. You'd need 2 Dishes, pointing at 2 Sats running into the 42 Switch, which would combine them. I think once you get the correct LNBF, you'll be in business!
Reactions: charlesrshell
Note that there is an adapter/yoke on the LNB that differs from the DirecTV version. The Dish LNB has one curved side, making it appear more like the letter D. This may give you grief trying to mount it securely in the right spot.
It could be a 322.
The right hand side looks different from the picture of a 322 I found. For one thing, the 322 has silver buttons, whereas on the 311 they are black. If this receiver was returning some free channels recently, then I think it can't be a 301.
If that receiver won't let you get to the signal set up area, then I do have an old dual-tuner receiver that I could send you for this purpose, if you are interested. You would have to pay the shipping, of course. Still, that would be a lot cheaper than buying a new good-quality signal finder meter. :)
Alright so I only need the one satellite signal though to be able to use the 42 switch and the hopper 3 ???!
I might have to take you up on that as well, I just need to find an LNBF and make sure that the LNBF can easily attach to my dish.
they looked like they attached a little different than the older styles.
I can't say how recently, I would say within the last 2 years but not Within the last year. I'll take a better picture so we can wrap up
On the receiver!
We had another worker come into the camp and according to them this wasn't the original LNB for the system. The LNB was stolen and the person who stole it replaced it with this LNB.
On the receiver!
Which explains the electrical tape holding it on?
Question on H3 DVR Space
Joey 4K + Vizio TV + Vizio Soundbar Hookup Question.
