Hoping for a little help | SatelliteGuys.US
DetFan
2,029
121
Livonia, Michigan
I have a VIP 212, DP 625 and 3 DP 301's 2 of which i purchased.
This 3rd 301 is really giving me fits. I just got it all hooked up today after buying a DP34 switch. Now main switch is the DPP44, and all seemed like it was going well. I can only get one sat and I have no idea as to how to get it see anymore.
all it is is seeing is 119. Originally when I started it up and did a check switch it told me that there are not the same amount of sats, and asked me if I wanted to save it or exit, I think i hit save, and I think that may be my problem, unless I just have the switches hooked up wrong.
Anyone have a diagram of how this should look? or any ideas?
I'm lost.
Three of the outputs on the right side of the DPP44 to the three inputs of the DP34, that's about all there is to it. If your DPP44 has all four inputs actually in use, you will need to choose which satellite to omit to the DP34.
Crank calls from Dish network
