History, biography @101w low signal | Page 4 | SatelliteGuys.US
what size dish? 10 footer? ;)
Man I need to put ku on my 12 but it would be a pain I really don't want to deal with. I love my ADL RP1C, c band only feed. I could never find the original RP1CKU, ku feed that was made by ADL. The knockoff is made by Patriot there not as good as the original ADL. I need to go borrow my clients 6 foot Fortec Star off his roof one night, bring it home and put a ku feed on it. :rolleyes: He'd never miss it :D :angel:
Hey Ice
Hey Ice is there anyway you could make up a conversion chart that could give me a better taking on the different receivers quality level. When I see 80 and 90 I think it's really smoking as it would on a Pansat. But on other receivers it may be like 60 on the Pansat. Do you have a rule of thumb we can go by :confused: Or can post some thresholds of receivers you use? :)
sure...lemme work on that. I've worked with enough receivers I can probably remember how they work signal wise
issue with Coolsat 5000 is the meter reads 70-72 and on the Pansat it could be a 45-50 or 74. Thats the issue with the Coolsats versus the Pansats
Kewl it will be a nice reference. Drives me nuts when I see someone posts there getting a 90Q and there threshold is 85 :eek:
My Pansats threshold is 19 from what I've seen.
Thank's Ice :)
Southwest Missouri, 3:40 PM CDT, mostly clear skies
Setup #1:
90cm 3ABN
WSI single 521 LNBF (the light blue one)
Visionsat IV200
DG380 motor
85% Q (threshold is around 20%)
Setup #2:
90cm Fortec Star
Techsat TrackerII single LNBF (the red one)
Coolsat 6000
STAB HH90 motor
91-93% Q (threshold is around 63-66%)
I'll try to check in again tonight and see where my stuff is at then. :)
STL, Mo _ 90.6w
4:12pm, cloudy overcast
JSC322 Ku Lnb
Primestar 84e
cnx duo
35 quality with a threshold of 30 <- ignore
I removed my C-band project which had my Ku 15º off center.
With my Ku dead center:
75 quality with a threshold of 30
4 pm 72 SQ
8:20 pm 35-40 SQ
Borderline on my Traxis 3500 with 80 centimeter dish.
Must be the bats. :rant:
It just started doing this a couple of weeks ago. I thought it was just me.
Seems like PM hours would be prime time for those folks. :confused:
Fortec Star 90
Invacom Quad
STAB HH100
Coolsat 6000
6pm PDT = 66-67% signal quality. Picture seems solid.
So between 4pm and 8:20pm EDT it went bad? Now if we can just narrow that down a bit further. If it is the uplink or transponder it should go bad for everyone at once.
BLSA attached. I'll leave it skyscanning overnight if I can remember to not use the dish for something else. ;)
Southwest Missouri, 8:40 PM CDT, mostly clear skies
Setup #1:
90cm 3ABN
Visionsat IV200
DG380 motor
61-63% Q (threshold is around 20%)
was 85 % @ 3:40 PM CDT
Setup #2:
90cm Fortec Star
Coolsat 6000
STAB HH90 motor
86-87% (occasional bounce down to 70%) Q (threshold is around 63-66%)
was 91-93% @ 3:40 PM CDT
10:27PM EST NY.
86-88% Q Coolsat 5000.
12060, 12 to 15 Q here at 10:25 pm in bad shape. CGN 60-Q 12116 H for reference, all others on bird V & H fine.
Wonder if it's something at the uplink vs the bird?
Fortec Star 90
Invacom Quad
STAB HH100
Coolsat 6000
If it's not the bird or uplink there has to be some type of interference causing this. It can't be localized since most are experiencing it. Could there be some phenomenon happening in the atmosphere that is creating the problem? But why only one transponder frequency and bird? Baffling :confused: :confused:
Did a check of the data transponders (as well as all transponders with channels) at 11 am and again at noon and then at 8:30 pm.
No other transponder suffered a loss such as 12060 did. Most were fairly stable, some had increases, and a few had minor losses (the highest losses were in the 10 to 15 range). But there was nothing that you don't normally see day to day, except for 12060 (which we are actually seeing day to day, unfortunately).
Like I said baffling??? In this case you would think it's the uplink. Here's a twist could moisture or heavy humidity be playing a role here? Does anyone know where the uplink is? Maybe we can study weather patterns there.
This weekend i was at my camping site i use a 36'' dish
with a twin output linear lnb.
My friend and me are connected to the same dish.
He watched History all nite on Saturday with a VS Ultra 2000 with 60% quality.
On my Ariza 700 i had about 15% quality, no way to watch History or Bio.
Does anybody can understand why? I dont....
STL, Mo _ 90.6w
9:33am, cloudy overcast
JSC322 Ku Lnb
Primestar 84e
cnx duo
45 quality with a threshold of 30
It was 75Q last night and down this morning. It's usually the opposite.
[edit] RTV E/W are down 20Q points this morning, so it's likely weather related for me in STL.
Did you try switching outputs on the LNB just to check to make sure nothing was wrong with the one you were using? or swapping cables?
Just curious, cause that one really makes no sense outside of something flakey on your setup.
Is Press TV on 97w blurry for everyone?
GeoSatPro 1.2M Dish Damage and Setup.
