hi i need help | SatelliteGuys.US
hi i need help
Elevation: 38.2°
Azimuth (true): 179.8°
Azimuth (magn.): 179.1°
LNB Skew [?]: -0.1°
Did you find this data yet?
What have you tried so far?
Did you put the dish up or was it there from before? Tree's in the way?
Does the Primestar dish have 1 or 2 outputs?
It's real easy to find if you are home at 1PM CDST. Leave the elevation alone and just aim the dish at the sun at exactly 1PM (12PM during non daylight saving time) 93w is your "True South" satellite
welcome :wave from another Twin Citian :) (SW suburbs....near Mistake Lake) ;)
actually this look like the MN thread since we are all from MN ;)
93W is our true south so its almost dead south. Make sure the receiver has the right settings
STANDARD
10750 LNB Freq/LO
Transponder is 11983 V 8681
On the Primestar dish you may have 2 separate outputs. A picture would help but one may say "V" and one says "H"...use the V side
Cyberhome / Sonic Voom connector
motor woes
