Help with motorized dish elevation | Page 3 | SatelliteGuys.US
No. You have an offset dish so you don't have to worry about declination that's why the dish is offset. The only adjustment you have to make is the elevation. You set the inclination on the motor to your latitude from your pictures that's 34 degrees. Set your dish elevation to 50.47. Point the dish true south and follow my previous instructions.
You don't have to be a mathematician here your over thinking the problem. Keep it simple.
Hello bobvick, I have the same dish and the same question as you did. What was ultimately the resolution of your problem? Is it what nosbod suggested?
DISH NETWORK WITH MY FTA DISH?
Automatic Polarity Controller
