help in setup screen? what dish? | SatelliteGuys.US
mots-a
93
Hello -
I got a new hd dvr today.
I hooked it all up and now I am at the dish selection screen, well there are 15 options to choose from.
I dont own a slimline dish My dish is the larger more square shaped dish with the side car LNB.
so i can anybody tell me which dish to choose?
and do I select SWM or multiswitch?
thanks
mots-a
The Dish that you have is equivalent to a 5LNB Multi-sat. The newer receivers will auto sense the dish type. Just hook it up and it should figure out the correct setting.
Cables Question
Install scheduled -- worried about installer
