HELP - finding channels | SatelliteGuys.US
Digital Rain
SatelliteGuys Guru
143
ALBUQUERQUE, NM
I have a DSR-550 unit - recently got a remote - thinking I could go into a simple menu and scan for local HD channels, only to find there is no menu for that. if there is I can't find it. plus i don't want to do something that will make it useless. I have read though the FAQ part of this site and cant find the anwser to my problem. I do have the current NEP 737 - cant find the software ver - but im sure it has the last and latest software.
Press Voom
Press the green button
Press green button again
put in the password (try 0000)
this is the system settings menu
Go down to 7 - the installers menu
go to installation wizard
go to #4 which is scan local channels
You might want to check antennaweb.org to see what direction your channels are in...digital channels are more picky where the antenna is...I have two poles...one straight and one across...pbs's seem to be in one direction and everything else is in another
Also scanning during the night might yield more stations. I tend to get from a indoor antenna channels within 30 miles.
To check your software version, press Voom then the green button twice this will take you to the system settings menu. Scroll down to #6 system status and hit ok. I think there are three pages of information to look at simply hit the down button to veiw them.
Possible Killer News For Voom Tos Use!!!
Aiming off-air antenna
